Quick question... would you know if the rb26dett on a BNR32 has an oem boost limiter aside from the restrictor tube? is there a boost limiter that is electronically controlled? if there is, how does it limit the boost? ... through fuel cut or through ignition cut? also how do i take it out?
reason i'm asking is i get a sort "misfire" at high rpm (7000++pms)... my car runs on a mines box with a piggyback emanage now... i also noticed that the "misfire" occurs at around 1bar or a little above 1bar of boost.... i'm wondering if this is a limiter that comes out with the high boost/rpm.... what do you guys think?
