1 - 13 of 13 Posts
I want to replace the standard rubber pedals on my 32GTR with s/s drilled ones. Can I use the off the shelf ones I've seen in Halfords (Ripspeed & others), or will they not fit without a load of hassle?
Thanks.
Have you seen the R34 V-Spec 2 items?
Aluminium drilled, and all 3 pedals.
Replace the existing plastic ones, apart from needing a bush which i have the part# for if you are interested.
Thanks for that mate.
I'm off on hols in the morning (actually in about 7 hours time - I hate early flights) - so I'll be back in touch in a week's time.
what ever you get make sure there are rubber pads on the brake pedal or a 'keen' MOT tester will fail it
The V-Spec 2 items have rubber dimples, and also rubber on the extreme edges (left and right)
Factory items after all
some of the crap in halfrauds doesn't though
got any pics of them?
According to the link i've given, they should fit, and appropriate part#s are there
You will need
1x 18014-AB000
1x 18014-AB001
One is a bush, and one is the clip. But Nissan list both as a bush
1 - 13 of 13 Posts
