1 - 13 of 13 Posts
Hi,
We are able to supply and the Ohlins Road and Track suspension for the R35 GTR.
As you will know Ohlins make some of the best suspension in the world and the R&T kits are no exception.
We had these fitted our Evo X demo car for nearly 4 years and they were faultless, the car was smooth and compliant, on track it was something special.
If you are looking to take the handling of your GTR to the next level you need to take a good look at these.
More information is available here
Nice piece of kit Ant :thumbsup: Just put a set on mine and they're very smooooooooooooooth :D
I'm in the market for new OEM or aftermarket.
Are there any suspension specialists for the GTR?
I dont want to buy aftermarket and not have it set up professionally.
Anyone can buy and fit these.
Any recommendations.
Discussion Starter #10
How far do you want to go? We can do from just fitting and alignment to corner weighting etc :)
I'd recommend Centre Gravity once you have it fitted, got my car done there, and were extremely helpful and knowledgable on suspension setups etc
Does mean you get alot more than just 3 settings on the dampers so can fine tune to your needs :)
The damper setting in the car is a load of balls anyway
May well be, but I like it, use it fairly regularly and think its a great idea for road car that gets taken on track. I dont want track quality ride when I am driving down a busy potholed road.
Graham, sounds like you want the litchfield suspension set up if you want to retain the adjustment but still want awesome suspension.
1 - 13 of 13 Posts
