are they worth using or is the standard type system worth keeping
just debating on buying one and wanted to know the pro's & con's
+1:thumbsup:Install a catch tank and then route the line breather line from the catch tank right to the back of the car otherwise its going to stink the cabin out.
Thats the way I had mine, at first it just went under the front wheels and the fumes came into the cabin, then the pipes were sent to the rear and the smells gone.
never thought of that mate, did similar with removing my carbon canistersInstall a catch tank and then route the line breather line from the catch tank right to the back of the car otherwise its going to stink the cabin out.
yes it will just as mine is doing now it smells when i open the windows strangely enough.... but the heater fan does not suck the smell inside the cabin mmmm....Install a catch tank and then route the line breather line from the catch tank right to the back of the car otherwise its going to stink the cabin out.
you'd be amazed how much dirty water vapour they collect ...not so much oilUnless your tracking the car or else pushing serious power i dont think id bother..
Do you have a pic of that?I use the NISMO oil seperator, it has a line that feeds collected oil back to the oil pan.
I'd like to see that too!Do you have a pic of that?
