Firstly is there a guide here for changing the oil on an R32 GTR?
Second, do you guys generally just dump old stuff out and stick new stuff in? or do you run any of the 'flush' fluids through at all?
Anything else reccomended that I should do other than sticking in a new filter?
D.
Having hands the size of a small child would help! Its a little awkward to get the filter on and off and you will see why people buy filter relocation kits, you may have to move a few pipes etc to one side just temporarily tie wrap them to give easy access. be prepared to spill the residual in the filter on the floor and its a waste of time pre filling the filter as you will throw that on the floor too! Personally i wouldn't flush, just do regular oil changes with good quality synthetic oil. Oh and i took the under tray off mine as I had visions of the sump emptying itself into it!!!
Hopes this helps Ed
Seriously?
Take sump plug out, take off oil filter, allow to drain. Attach new oil filter, attach sump plug, fill with new oil ~4.5l, check level, job done.
Same as it is on any other car.
Pikey said:
Seriously?
Well without meaning to sound rude, yes seriously!!
The absolute LAST thing I need to do right now is go at it 'like any other car' and then realise that because I'm not a mechanic, and not entirely full of knowledge of the RB26 and make some cockshite mother of an idiotic mistake (like "DUDE! you didn't realise that the RB26 is slightly dfferent and needs 'A' done before you do 'B'.... Dam thats nackered now!!" that ends up costing me the ability to afford and drive the car - so I thought I would ask first! .....so, now I know - thanks.
EDIT: I also did a little more searching and found Senna's word document guide on here - Cheers
