1 - 7 of 7 Posts
I require an oil cooler kit for an R33.
Preferably a kit for the R33 specially with all necceesary fitings.
How much did it roughly cost you and is there a part# for the cooler you used.
I guess you fitted it ebhind the grille???
Thanks for your help
Cooler and assoiated hardware was around £140
Pipework depending on what you go for is anywhere between £100 - £225
I got top of the range pipework (aeroquip with swival ends)
Total cost around £360
And yes cooler (13row) behind the front grill.
I took an oil filter to them and they made the kit up from that :D
Best regards Alan
Can you just clarify one thing.
Is the cooler 135mm width or 225mm. (I think those are the dimensions)
It's just that those are the only two widths available.
I suspect its the first one.
Cheers matey
much appreciated
1 - 7 of 7 Posts
