Just your thoughts on above i went about changing the oil and filter today and what a pain.. Its no wonder a garage must charge what they do,,, two pans have to be removed to get at the oil filter... I know nissan have put a quick access with an oil symbol on the pan... But if used it would be like papering the hall through the letterbox . I use the suction method to remove the oil so no need to drop the pans.. I was tempted to cut a quick access panel big enough to get a strap wrench on the filter.... Time is money""""""
