I got the engine back from the rebuilder (what a :chairshot ) never hope to ever bump into him again. long story ill save for later
anyway the oil filter housing doesnt fit because all the vacuum and water lines under the inlet plenum are blocking it besides its a crazy adventure under there.
so we removed all that and then fitted on the oil fitter housing. now the bloody vacuum chamber dont fit. its blocked by the oil filter housing. if we try to fit it, needs a bracket, and extended water pipes, which I've looked everywhere for and cant find a source.
i was thinking if an oil filter and cooler relocation would sort it out?
heres an image i found elsewhere:
the space is just too tight
please help thanks. this is the thing hindering it from going in the car
