1 - 6 of 6 Posts
Anyone know wat would cause really low oil pressure it's at 6bar when it's cold but less than 2 when it's warm
depends on what gauge you use, 2.0b on an accurate gauge is acceptable if you show 6b when cold IMO. You could change your pressure sensor switch as these are notourious for failing and showing inaccurate measurments. Ambient temp also plays a roll in what your gauge indicates and when the airs cooler the oil pressure remains higher due to the temps. My 34 shows 8b when cold in winter.
Yeh it's not the gauge though cause it starts getting a noisy top end when it's warm
advise caution, a noisy top end can very quickly turn into a noisy bottom end!
check oil level and oil colour in cap. if your at all unsure get it checked by a proffesional!! where are you?
kev
1 - 6 of 6 Posts
