Oil pressure gauge has been reading lower than i'm happy with, so stuck a test gauge on it yesterday, and everything seems fine. From what I've read, it will likely be the sensor at fault.
Any recommendations on where to order a replacement from? And should I be going OEM or are there aftermarket sender's that work with the original gauge that would last longer?
It's an R32 gtr, and the sensor in the car looks to be old.
Thanks Matty. Got an OEM one last week and fitted it. My mind is now at ease so can start getting some use out of it now!
Ye, gauge working spot on now. No more worrying about my engine needing a rebuild.
