Just noticed when I get above 80mph my oil pressure is getting up to 7 whatever they ares. Is this normal or is it time for an oil change?
Oil pressure
Sounds like a strong mill mate! What do you get on idle? 2.5 -3 Bar? Only thing I can think on off hand is overfilling... Still better to have too much than too little. Mine sits about the same level, so either that's normal, or their both knackered!
Check your oil level first off. Changing it won't do any harm either.
Is it still rising ok when you go on throttle?
Andy T.
What oil pressure to Skylines normally make in the upper half of the rev range?
Oil viscosity can affect pressure too.
Is there a relief valve to limit the max pressure?
Matt,
Normal mate, you can relax :p
Should be about 2 'of em thingies' at idle, about 4 @ 2krpm and over 6 @ 3.5krpm
Cheers Jason, didn't think it was too serious but I was beginning to have visions of the thing blowing :p
Matt
