I have a 95 r33 vspec, it has various mods and greddy external oil cooler. When I start her up the oil pressure is nearly 8 something on the dials and settles down after warming up. When i accerlerate the oil pressure goes up to about 7 on the dial depending on the rev.
My question is this quite normal ? and if it is how can i tell if internal work on the engines has been carried out i.e..piston etc..
apologies if this has been covered before. :)
Skyline Section Manager
Oil pressure sender on GTR's are really unreliable.
The max pressure according to the book is 6bar. This will depend on the oil you are using.
Yes, this is quite normal, and yes this topic has been covered a time or two before. Use the search button and all your answers will be there..
going off the topic, is it easy to spot an metal gasket upgrade on the block ?
ray :)
