Hi guys!
Does anyone know if this o'ring has to be placed between the pickup pipe and the gasket? Because when I am tightening up the bolts of the pickup pipe, the o'ring strangely squeezes too much that it doesn't stay in place. Do I need to fit it...is it a must?
The age of the block dictates which seal is used. either a seperate rubber ring and a flat plate or a plate with ring included. If its not fitted the pump will not pull up the oil through the pick up pipe correctly.
