Ah, in that case the answer is yes and no. It will phisicaly fit on, but the RB25 crankshaft has the small oil pump drive a-la early GTR engines. This is fine on standard pumps but an uprated one will shift quite a bit more oil, and put more load on the driving surfaces, the flats of the drive on the crank nose only have around 3mm of contact with the oil pump. If you're going down this route you really need to fit a oil pump drive collar to the nose of the crank..
