Hi All,
I've heard and read a fair bit recently that N1 pumps are made of a weaker sintered material (the gears I mean) and there have been a few instances of breakages over here in Aus.
IT 'seems' the the main reason for them breaking is when guys are using launch control/limiters and the like, or high rpm launches etc. The limiters essentially 'chatter' the drivetrain and crack the gears from what I understand.. and the big rpm launches - well that is self explanatory.
Obviously it doesn't happen in all cases.. but I don't want it to happen to me.
So! The solution, one would think, is simply to find a pump that has better materials internally and we all know Tomei, HKS, JUN etc have pumps to choose from.
The problem for me, is this. All these pumps are 'high volume' pumps and one of the problems with RB's is that they already pump far too much oil upstairs into the cam covers. My motor is having restrictors fitted to the head, an external drain to the back of the head and an 9L sump with gates and so on.. but I am still lead to believe that there can be problems with 'too much' oil be pumped up there..
I know that the Tomei is the only one adjustable, but it also starts off as one of the biggest in terms of volume! So I am not sure if this solves it. Can anyone who does some circuit racing tell me of their experiences?
Is it better for example to buy the Nismo Pump (as opposed to the N1 Pump) for longevity without the high volume of the Tomei? Or buy the Tomei and 'turn it down' as much as I can?
I also note that Reimax make an 'uprated' gearset for the N1 Pump. Maybe this is the best alternative as it keeps the volume down to 'enough' and fixes the possible weak point in terms of breakages...
http://www.reimax.com/eng-oiln1.html
Love you hear your thoughts and feedback.
My motor will be a 3Litre version (not OS) running about 650hp at the engine and limited to around 8000rpm - in case that has a bearing on the selection of pump.
Cheers!
Matt.
Cheers!
Matt.
