1 - 20 of 22 Posts
I'm assuming it's just wider wheels due to the extended arches but love seeing all that rubber at the back
Also, is that a custom boot lid? Lines up perfect
That's the style I like, fat and wide and smooth, no sticky out bits like big spoilers
Gtr, I thought the same but if you look at the doors you can see the ridge running along, gts doesn't have that
Discussion Starter · #11 ·
Big wheels
spoiler delete
Cf rear diffuser
Cf side skirts
Steering wheel
Tidied up interior
All after a new gearbox and passenger seats
Then probably a bunch of other stuff
But not until next year
Lol Bet the list is just getting bigger and bigger
Judge, if you're going to do it make sure it's on a 33 not a 32, please. Either that or buy a road roller if you're so keen on that wide look.
Discussion Starter · #13 ·
I won't go over the score, here's my arches now, just need to fill the gap a little
Nothing like this though
Jt judge did the body shop cut you arches right out or just stick the arches on? That will be the limiting factor on wheels and as you didn't have fronts done you will need 2 diffrent offsets what looks silly imho
Discussion Starter · #19 ·
They cut a large part out but then built it back up with metal then bonded the arches on. The front qtrs would be getting swapped with wider ones. Similar to Matt's
1 - 20 of 22 Posts
