1 - 9 of 9 Posts
Anyone using a one-piece propshaft and if so, what are the advantages / disadvantages on the road?
Following EJH#25
I have one and don't notice any difference tbh, less backlash and weak points but on the road, it's very difficult to tell.
My centre bearing is becoming a bit noisey, so would I be better off with getting a one-piece or just sticking to a 2 piece?
Following EJH#25
Depends what kind of power you're running and what you use the car for tbh.
There's nothing wrong with the standard shafts, I just went with a single as I had it and I use my car for drag etc where the benefits are greater than just road use.
Matt J, if you don't me asking what are it's benefits for drag racing? Am new to this.
Thanks in advance.
I use a carbon one piece on the Orange.
Advantages:
Less parasitic loss from centre bearing and UJ
They are usually made from alloy or carbon giving a double benefit of less overall weight and less inertia to overcome meaning less power loss and more direct transmission of that power
Obviously its an "uprated" component so designed to cope with more power than stock
Less slack in the drive train to cause whiplash type damage to other components
Hope that helps
Anyone know where I can get an alloy one-piece propshaft for an R32?
1 - 9 of 9 Posts
