1 - 11 of 11 Posts
Hi lads have a r32 gtr with link ecu, full exhaust and pod filters and will only be used for road use and i wont be forging it. Now i want to get around 500 whp, i have been chatting two tuners and one says to use twin garret 2860-5 and the other tuner said to go single with garret gt3076r. Now there doesn't seem to be a whole lot in difference in price. I can't decide on which set up to go for now. Has anybody had experience with both setups? thanks
Prices will change alot once you go single..you'll need to get a good manifold, oil/water lines. New IC piping, downpipe and few other bits. Whereas the -5 just bolt on. I went single setup last year and don't regret it at all. I'm running a 6boost manifold with a 6266. It's only running 1.4 bar on a non forged engine at 630hp at the fly and it's really responsive too. Id say a gt30 is too small and would need to run high boost to. And people don't advise running alot more than 1.4 on an unopened engine
Sent from my SM-G955F using Tapatalk
Gt30 is on the money for 500bhp. Get a gtx and you will be laughing.
I like the simplification that happens in the engine bay plus THAT sound!
Discussion Starter #4
I was given the same setup turbo you have by another tuner. Have you cams or head work with your set up? When does your boost kick in?
Thats another thing about single setup is i haven't heard anyone regret going single instead of twin setup
I was in the same boat as yourself last year I didn't know what to do but thankfully I went single turbo and I think me and dave will both agree the power and sounds are amazing plus it drives so much smoother around town and that than it did with standard twins.
Dont even think of goin gt3076 turbo, it is old as your skyline. Market is full of modern, high-performing turbos, and buying Garret GT is really waste of money.
Go for garret GTX or BorgWarner EFR
Single turbo will be costy for you, because you will need to modify more, but it will end up in much cleaner look and easy maintaince. Also the spool of correct chosen single turbo producing 500hp will be earlier than twin doing the same.
Owner of the MSNSPS
This is very true. Also worth noting that there is much variation in the other kit. How good a manifold will you go for. How solid will it be. Good manifolds which won't be cracking seem pretty pricey and along with the other accessories the total cost will soon mount up.
Would the cost differential be better spent on other things - wheels/tyres/brakes/bushes/etc.
Not trying to put you off but its worth considering the whole picture
Discussion Starter #10
Thanks for the replys lads. I will be more than likely getting a single turbo set up and i will be usng a 6boost manifold. Now i will have to try decide which turbo to get.:D
Discussion Starter #11
What single turbo did you get?
1 - 11 of 11 Posts
