OPTIMA® YellowTop® DEEP CYCLE BATTERY FOR EXTREME APPLICATIONS
The OPTIMA YellowTop is made to install and forget. No matter the conditions, be it dampness, heat, dirt or exposure to extremes in vibration or regular discharge, it is guaranteed to deliver uninterrupted power throughout the entire discharge cycle. The ability to hold a higher voltage during the discharge cycle makes it possible to utilize more of the stored power in the OPTIMA, compared to ordinary batteries. All of these benefits are due to OPTIMA’s Spiralcell® Technology, which combines the advantages of a starting battery with those of a deep cycle battery.
3 x Quicker Recharging (as compared to a standard battery bought for the same purpose)
The YellowTop handles many discharges as well as re-charges without losing significant capacity and is also ideal for seasonal use because of its very low self-discharge rate.
OPTIMA YellowTop batteries are made for the extremes. Whether your vehicle is designed to crank out the decibels or take the abuse of off-road driving, you need more from your battery. OPTIMA Batteries with patented Spiralcell® Technology deliver deep cycle characteristics coupled with an extreme resistance to vibration.
Over 15 x more Vibration-Resistance (as compared to a standard battery)
This combination provides performance vehicles with the repetitive power they need in a spill-proof package. If your vehicle has a lot of accessories like high performance stereo/AV systems, extra lights, winches or hydraulics it demands more from its battery. OPTIMA YellowTop batteries provide the extra performance and cycling capability that your vehicle demands.
Dimensions:
Length (MM) Top, Base
237, 228
Width (MM) Top, Base
129, 121
Height (MM) inc Terminals
227
Gross Weight (Kg)
11.8
Terminal Layout
CCA (SAE)
460
Voltage
12
Capacity (Ah)
41
Reserve Capacity (Ah)
66
Optima Yellow Top AGM Batteries – The Ultimate in Performance, perfect for your high performance Nissan GTR.
One we fitted to a GTR:
To place you order for next day delivery please call or email us.
£160 + postage/fitting
