1 - 6 of 6 Posts
I noticed today i've got wear on the front tyres outside edges:confused:.... i've got tien coilovers fitted, but i'm not sure what i'd have to change/adjust to fix this problem?
any help is greatly apprecieated.
Rob:thumbsup:
Odd; normally the insides wear due to the camber change when lowering (iirc). I think it's the camber which needs adjusting (but it could be toe, thinking about it); correct settings are on RSP's site.
Sounds like positive camber. Check and see if any of your bushings are busted and then get your toe in adjusted if possible.
If both edges off the tire (in and outside) or more worn then the inside the tyre pressure is way to low. And outer edge wear can also suggests a low tyrepressure in combination with bad aligning off the front wheels ;)
PornStar Member
As your location seems to be Saaarf London, speak to Abbey, they have a computer controlled wheel alignment rig, which sorted out my skittish handling a treat, and corrected my camber settings.
I'm sure that will help identify the cause of your un-even tyre wear.
1 - 6 of 6 Posts
