1 - 19 of 19 Posts
running 400mm alcon discs , where best place to get the above pads for them ?
ta
As above, I believe Litchfield have them on the shelf.
BBK fitment on Steve's, not sure if that's the difference. That said my recent replacements were similar to Jamie's costs.
You paid £1200 for a set of brake pads...?!?!?!? :runaway:
yep, before the prices started to come down, like all things new you get b*ggered !!!
Im sorry but £430 for a pair of front brake pads and £270 for the rears is ridiculous.... GTR tax at its best. Its a joke.
Is there any significant increase in braking force using the Pagid pads with OEM disks then? Been looking at changing my pads and disks from OEM but just not sure if they are worth it or not?
Fair enough. Thanks for being a front runner and helping 'reduce' todays pricing.
Nabster said:
Do need the upgraded Alcon disks or can you just use the Pagid pads on OEM disks?
I am running Pagic RS29 on AP disks. I am considering changing from Pagids to either Ferrodo DS2500 (possibly 3000 although not doing track work so probably not worth it) or maybe the Bendix which Trevgtr rates for road use as these are sub £200 for a full set
If you use the brakes hard enough to benefit from the pagid RS29's then you will find your stock disks crack and need to be replaced (in my opinion anyway).
Better to either change the entire lot (I can recomend the AP disks) or just change to a milder pad such as the bendix or the Ferrodo. A lot of peeps seem to also recomend the cosworth streetmaster too.
I have 2 of them and I not robbed but raped !!!!
  • Like
Reactions: Chronos
Certainly need to change the front discs, but I've been on stock rears with Pagids for some time now without any disk cracking issue. Pagids last quite well too ime.
Hence why I bit the bullet and went for the Alcon BBK - pads may be expensive, but disc's holding up well
1 - 19 of 19 Posts
