Paint Correction
"The Correction package"
Suitable for cars with light defects, e.g. micro maring, light paint swirls and holograms.
Your paintwork is checked for any micra marring, light/medium/heavy scratches, bird/water marks, swirls or holograms. Once your paintwork has been assessed we use a rotary polishing machine, and multiple passes with different grade cutting/polishing pads to remove as many detects as possible, before applying Dodojuice high Carnauba content wax or Dodo Juice Supernatural high Carnauba content hybrid wax (sealant and wax combined) to protect your paintwork from any future defects.
[We will require your vehicle for up to 48 hours.]
Cost: £POA
Vehicle rinsed using low pressure filtered water
Lower third sprayed with a non caustic citrus cleaner, and rinsed
Wheels, arches and door shuts cleaned by hand with a non caustic citrus degreaser
Wheels cleaned with a pH neutral wheel cleaner
Vehicle sprayed with a pH neutral snow foam, left to dwell and rinsed
Hand washed using a sheep wool mitt, with a pH neutral shampoo using 2 bucket method
Tar removed from vehicle
Hand dried using high quality, specialist, microfibre drying towels
Clay bar/clay sponge paintwork and glass to remove any contamination
Paintwork is inspected using a high Lumen light. Vehicle is then masked to protect trim, plastics and windscreen and then corrected using multiple stage passes to remove as many swirl marks, micro marring, light scratches, holograms, and bird/water marks as possible.
Pre-wax cleanser applied to ensure bonding of protection layer
Vehicle wiped down with IPA (Isopropyl alcohol) solution to remove any contaminants or oils from the polishing stage
Dodojuice high Carnauba content wax or Dodojuice Supernatural hybrid wax applied to paintwork, and door shuts
Chrome/stainless steel polished including exhaust tips
All interior surfaces wiped down with a citrus cleaner
Vents and trim gaps cleaned with a detailing brush
Interior Vacuumed (Including Boot area), and any litter removed
Interior glass and mirrors cleaned
Exterior windows and mirrors cleaned
Layer of detailing spray applied
Tyres cleaned and tyre dressing applied (satin finish)
Final inspection to make sure your car meets our high standards
