1 - 9 of 9 Posts
i need info on the oil and water feed pipes to the turbos.
im going to change them all before i fit anymore turbos
cheers john
can't you download them for a £1 ;)
depending on what you have / want and if you have the time you would be better off getting some custom braided ones made up with all the proper fittings swaged on the ends!
Often works out cheaper but entails more faffing around.
Best bet is a company like Pirtek, but maybe not Pirtek as they aren't the cheapest iirc. maybe yell.com a few similar companies in your area.
I'm going to change them all before i fit anymore turbos
cheers john
Don't put the stock ones back.
Make some flex hoses, steel braded... works like a charm.
It will probably cost less also...
Asim...
garrett gt2860's
theese have allready been on the car twice :chairshot
before i fit a third set i want to replace the lines,ive heard the standard ones are fine. ?
i want them asap aswell.
if ever u use the flex make it sure that they r heat/oil resistant....
regarding the size of the flex u should refer to the new turbos specs..
1 - 9 of 9 Posts
