Status
Not open for further replies.
1 - 20 of 28 Posts
GT-RDC Founder Member
1000’S OF USED AND NEW PARTS AVAILABLE this is a smidge of what we currently have in stock
R32 GTR Parts
R32 GTR N/S front wing £350
R32 GTR N/S front wing creased £195
R32 GTR footwell trim cover o/s with flare holder £60
R32 GTR centre console (arm rest) £25
R32 GTR Steering column cover top and bottom £55
R32 GTR Lower steering column £29
R32 GTR Lower dash trims without vents £25
R32 GTR Ashtray £129.99
R32 GTR lower dash trims, modified £15
R32 GTR lower column trim £30
R32 GTR handbrake lever and with working ratchet £65
R32 GTR lower centre console, with rare oem knee support pad £295
R32 GTR door coin pocket £15
R32 GTR door handle lever surround (not sided) £15
R32 GTR n/s boot corner carpet £60
R32 GTR firewall panels £25
R32 GTR boot carpet panels o/s £60
R32 GTR dash board has vinyl crack £160
R32 GTR fuse box cover £50
R32 GTR passenger side pillar trims £30
R32 GTR interior sill trims £65 pair
R32 GTR drivers side pillar cover £30
R32 GTR full boot shut trim panel £40
R32 GTR lower centre console £25
R32 GTR n/s/f hub good bearing £159
R32 GTR o/s/f hub good bearing £159
R32 GTR o/s/f hub complete £159
R32 GTR n/s/f hub with shield £159
R32 GTR o/s/r hub £159
R32 GTR n/s/r hub £159
R32 GTR o/s outer door trims £65
R32 GTR rear bench top half £100
R32 GTR pair rear brake calliper’s £120
R32 GTR o/s front callipers £75
R32 GTR scuttle panels £70
R32 GTR undertray £40
R32 GTR kyb shocks and springs set coil overs £50
R32 GTR atessa and hicas pump £275
R32 GTR frp front cooling panel £20
R32 GTR power steering brackets £50
R32 GTR air con pump brackets £25
R32 GTR speedo cluster £195
R32 GTR rear wiper motor £59.99
R32 GTR Iac valve £45
R32 GTR orange rear strut brace £245
R32 GTR centre dash 3 gauge cluster £99
R32 GTR Light cover N/S £35
R32 GTR Light unit O/S £74
R32 GTR RADIATOR SHROUD NO MODS OR CRACKS £70
R32 GTR Passenger wind deflector £95
R32 GTR Door cards £50 with no trim
R32 GTR Inner rear quarter cards £50 no trim
R32 GTR Drivers side front wing £350
R32 GTR Full mat set £135
R32 GTR AIR CON PUMP X 2 STOCK £125
R32 GTR Hicas control valve £49.99
R32 GTR Power steering pump £295
R32 GTR Full front arch lines £350 pair
R32 GTR Wiper switch £69.99
R32 Automatic transmission ecu £49.99
R32 GTR Viscous coupling fan £74.99
R32 GTR VEILSIDE STEP 2 ECU TUNED £129
R32 GTR Brake master cylinder £79.99
R32 GTR SPACE SAVER Spare wheel £120
R32 GTR Heated rear screen switch £49
R32 GTR Mirror switch £14.99
R32 GTR driver’s door window switch £14.99
R32 GTR DOOR HANDLE SURROUND £12.99
R32 GTR Door handles £8.99 each
R32 GTR HICAS ecu £199
R32 GTR Gearbox cross member £95
R32 GTR Undertray front £40
R32 GTR Boot carpet £50
R32 GTR Metal door guide trims £290 for pair
R32 GTR Genuine Nismo strut brace with BMC Stopper finish R35 GTR Grey £475
R32 GTR NISMO SUPER SHORT QUICKSHIFT BNIB £295
Genuine Nissan Brand new rear quarters available £550+vat
Genuine Nissan R32 GTR Front and rear set of window seals with moulding £503.96 + vat
R33 GTR Parts
R33 GTR o/s rear interior quarter panels £50
R33 GTR airbag ecu £45
R33 GTR sill trims £30 pair
R33 GTR steering column cover trims £25
R33 GTR centre console £25
R33 GTR rear exterior panel (below boot lid) skyline embossed £25
R33 GTR rear view mirrors £25
R33 GTR o/s footwell trim plastic £18
R33 GTR n/s footwell trim plastic £18
R33 GTR radiator trim cover £55
R33 GTR dash facia £55
R33 GTR side skirts £280 full with caps
R33 GTR series 2 dash board £79
R33 GTR dash clocks £10
R33 GTR hazards switches £10
R33 GTR wing mirror switches £12
R33 GTR boot side carpet no hatch for atessa £30
R33 GTR boot side carpet GTS £25
R33 GTR rear boot panel £29
R33 GTR atessa pump shield £20
R33 GTR fuse box cover £30
R33 GTR sun visors £20 each
R33 GTR Headliner £100
R33 GTR b-c pillar interior trim n/s £20
R33 GTR b-c pillar interior trim o/s £20
R33 GTR boot lid carpet £40
R33 GTR o/s quarter glass £99
R33 GTR o/s door glass £50
R33 GTR n/s door glass £50
R33 GTR o/s strut top panel £99
R33 GTR pair rear shocks oem with lowering springs £60
R33 GTR front strut braces £50
R33 GTR rear strut braces £50
R33 GTR O/S/F hub £60
R33 GTR n/s/f hub £60
R33 GTR n/s/f hub carrier only £60
R33 GTR o/s/r hub £60
R33 GTR n/s/r hub £60
R33 GTR boot lid (bonded shut) £50
R33 GTR aircon pump £69
R33 GTR Rear screen £200
R33 GTR front windscreens £150
R33 GTR abs control unit £69
R33 GTR non v spec attessa pump £189
R33 GTR power steering reservoir £30
R33 GTR v spec style rear spats £55
R33 GTR Brembo front callipers £695
R33 GTR Brembo rear callipers £395
R33 GTST Front indicators £40
R33 GTST rear spoiler rubber gaskets
R33 GTST Coupe set of 4 Coil springs £65
R33 GTR Rear boot panel £29
R33 GTR rear arch spats £49
R33 GTR Aircon pump £95
R33 GTR Coilpack harness £99
R33 GTR BONNET HINGES PAIR £80
R33 GTR GTST front wiper motor £39
R33 GTR B pillar trims spares carbon wrapped £10
R33 GTR Spoiler blade £100
R33 GTR MATS £145
R33 GTST GTR Heater control £65
R33 GTR Starter motor £69
R33 GTR Radiator and shroud £99
R33 GTR Rear lower A arm £85.99 each
R33 GTR Centre cluster £79.99
R33 GTR Boot catch mechanism £49
R33 GTR Spec 2 airbag £69
R33 GTR Speedo trim surround £29
R33 GTR Atessa ecu £189
R33 GTR GTST Centre heater vent £15
R33 GTR HICAS ECU £189.99
R33 GTR AIRBAG ECU £89.99
R33 GTR GTST Heated window and hazard switch £19
R33 GTR Wiper stalk £19
R33 GTR GTST DASH COIN pockets £9.99
R33 GTR GTST RH Heater vent £9.99
R33 GTR Mirror switch £12.99
R33 GTR Brake servo wiring harness bracket £19.99
R33 GTR Fuel flap release cap £9.99
R33 GTR NON VSPEC Rear drive shafts £190 each
R33 GTR Front under tray £40
Genuine Nissan R33 GTR Front and rear set of window trims £375+vat
Genuine Nissan R33 GTR front bumper skin £445.16
Genuine Nissan R33 GTR series 3 front splitter £493.14
Genuine Nissan R33 GTR Front splash guard RHS £70
Genuine Nissan R33 GTR Front splash guard LHS £70
Genuine R33 GTR Rear quarter panels LHS £550+vat
Genuine R33 GTR Rear quarter panels RHS £550+vat
Genuine R33 GTR Front window seal kit and moulding £161.71 + vat
Genuine R33 GTR Rear window seal kit and moulding £159.78 + vat
Genuine R33 GTR Vspec rear decal £10.75 + vat
Genuine R33 GTR Rear boot emblem £43.99+vat
Genuine R33 GTR Front emblem £36.34+vat
Genuine R33 GTR Boot floor £402.39 + vat
R34 GTR Parts
R34 GTR o/s lower footwell cover, no door £49
R34 GTR n/s lower footwell cover, no door £49
R34 GTR n/s dash footwell panel £49
R34 GTR Lower centre console £65
R34 GTR Glove box lid £49
R34 GTR Dash board £249
R34 GTR Bonnet release cable £65
R34 GTR Bonnet release mechanism £79
R34 GTR Lower steering cowl £55
R34 GTR nsf hub £169
R34 GTR o/s/f hub carrier only £90
R34 GTR o/s/r hub £169
R34 GTR n/s/r hub £169
R34 GTR n/s driveshaft £250
R34 GTR o/s driveshaft £250
R34 GTR aircon pump £169
R34 GTR ABS Control unit £165
R34 GTR passenger SRS airbag module £70
R34 GTR Kakimoto exhaust system cat back 2 silencer (test fit only) £395
R34 GTR Reverse light £50
R34 GTR Skyline footrest £25
R34 GTR atessa bottle and pipes £80
R34 GTR Heater blow £200
R34 GTR Lower dash £85
R34 GTR Rear 3rd level £40
R34 GTR Front wiper motor £55
R34 GTR passenger window switch £29
R34 GTR Centre console lower £35
R34 GTR RH lower dash trim mspec £65
R34 GTR STOCK FUEL PUMP £50
R34 GTR HANDBRAKE AND CABLE MECHANICSM £65
R34 GTR PASSENGER DOOR PULL HANDLE TRIM £55
R34 GTR INDICATOR STALK £29
R34 GTR INTERIOR LIGHT £25
R34 GTR WINDSCREEN WIPER STALK £29
R34 GTR STEERING WHEEL BACK PLATE £29
R33 GTR SPEEDO SURROUND TRIM 68240-15U00 £55
R34 GTR FUEL FILLER NECK WITH CAP £55
R34 GTR REAR LOW DRAG SPOILER LEGS £195
R34 GTR CARBON SILL PLATES £99
R34 GTR APEXI POWER FC ECU WITH HAND CONTROLLER £549
R34 GTR HKS SUPER DRAGGER EXHAUST £295
R34 GTR FRONT LOWER SPLITTER £395
R34 GTR STANDARD CLUTCH AND DUAL MASS FLYWHEEL £345
R34 GTR FRONT SPLITTER LOWER £395
R34 GTR SPOILER BLADE £395
R34 GTR MSPEC NUR rear anti roll bar £195
R34 GTR Front adjustable tie rod end £85
R34 GTR AIR CON PUMPS £149
R34 GTR Rear bottom A arms with poly bushes £180
R34 GTR BRAKE MASTER SERVO £149
R34 GTR Atessa ecu £289
R34 GTR VSPEC REAR DRIVE SHAFTS £249 each
R34 GTT HICAS ECU £149
R34 GTT NISMO REAR BUMPER £199
R34 GTR Rear quarter glass LHS £140
R34 GTR Rear quarter glass RHS £140
Genuine Nissan R34 GTR Rear quarter panel LHS £556.63+ vat
Genuine Nissan R34 GTR Rear quarter panel RHS £556.63+ vat
Genuine Nissan R34 GTR Front splash guard lower RHS £155.75+ vat
Genuine Nissan R34 GTR Front splash guard lower LHS £155.75+ vat
Genuine Nissan R34 GTR Front slash guard upper RHS £126.68 + vat
Genuine Nissan R34 GTR Front splash guard upper LHS £126.68 + vat
Genuine Nissan R34 GTR Vspec undertray diffuser £775.63+vat
Genuine Nissan R34 GTR Front window moulding £78.93 +vat
Genuine Nissan R34 GTR Rear window moulding £76.68+vat
RB26 Parts
RB26 plenum manifold £80
RB26 Steel internal turbos £895 + Exchange
RB26 Injector harness
RB26 Engine bay power loom
RB26 Ignition module
RB26 POLISHED twin turbo pipe with badge £150
RB26 POLISHED TIMING BELT COVER £160
RB26 aac valves £55
RB26 pcm valve £55
RB26 front diffs sumps £280
RB26 starter motors £100
RB26 flywheels r32/33 £40
RB26 std pistons and rods £45
RB26 TIMING CAM BACK PLATE £70
RB26 TIMING COVER IN RED £100
RB26 CAM ANGLE SENSOR £165
RB26 STD FUEL RAIL £20
RB26 Rear intake elbow £15
Rb26 front turbo intake pipe £15
RB26 Cam angle sensor £ 159.99
RB26 BLITZ SUS POWER INDUCTION KIT £160
RB26 HKS MUSHROOM INDUCTION KIT £180
RB26 BAFFLE TWIN TURBO PIPE
SPARCO HARNESS SET £99
RB26 USED OIL PUMPS £29
RB26 N1 GENUINE NISSAN OIL PUMP £245 BNIB
R35 GTR PARTS
Stainless non-resonated ypipe £295
R35 GTR Top A pillar trims in grey £195 per side
R35 GTR CBA Rear tail lights £175 each
R35 GTR front grille £69
R35 GTR TOP ENGINE COVER £99
Dave
Can you please send me details of exactly what is included in:
Discussion Starter #6
Was looking for the Modified baffle pipe option Dave , the split entry then ?
Hi, we do the modifications in house to order or £165 exchange. We do have small stock of them on the shelf if your unable to send yours to us. Normally takes a few days to turn them around.
Regards
John
Discussion Starter #7 (Edited)
Dave
Hi, its the complete kit. The only exception is the little metal outer tags between the trim pieces, which you would normal re use. We will have these available if you want them (used).
Regards
John
Hi, can you provide more details on whats included in:
ta
Hi Joey
Our Heritage Parts are brand new. That's what this is, brand new.
Ohhh ... whoops didn't even notice that. Could you send me some pics? I have an aftermarket front bumper... just want to make sure i can use the same mounting points from my bumper.
Would really help me...
Regards,
Joey
Discussion Starter #19
1 - 20 of 28 Posts
Status
