1 - 6 of 6 Posts
Hi All,
Fitting a tracker today but for the life of me can't find a permanent 12v live feed and a switched 12v live feed.
Has anyone found them and if so where?! I'm tearing my hair out here!:mad:
Cant remember off the top of my head my igntion live i used 12v sockets and perm live the door locks i think it was
Cheers for that. I'll grab the ignition live from the ciggy sockets, good idea. Where did you pick up the door lock perm live, do you remember?
From the fuse box mate. You can wire into fuse adapters then put the fuse on to that and plug straight back into existing fuse socket.
That's great, cheers. Is it the fuse box next to the battery, the vertical one? Called the IPDM I think. Didn't know the fuse adapters would fit in there. Looks quite tight!
Discussion Starter #6
For anyone else wondering about where to get a perm live from, the fuse panel on the drivers side, by the accelerator pedal was where I found one.
1 - 6 of 6 Posts
