1 - 15 of 15 Posts
Apexis out and back to HKS again.
Had these new Racing Suction Direct Drive filters put in. Pipes replace all the stock rubber to the turbos.
Waiting for a set of silver cage and green filters.
Mod. no. 3 on the way soon!
Ah
They look smart on the car Vince, they looked good in the box and on the HKS pictures we have, glad you took the first one off Gary, check out how much more air space he has around the filter elements, no longer stuck inside the wing with only mm's of clearance, see how the filters bolt directly onto the air flow meters?!
Discussion Starter · #12 ·
Thanks for all your replies!:smokin:
Apparently I'm the first to have these in the UK even though they have been available for some time!
Andy
Yes, there's much more clearance than the Apexis and previous HKS. I think they would look better with those silver cage/blue filters! I'm still waiting........
Dino
The car sounds deeper but not louder on idle after the change. Car seems more responsive as well when it starts boosting. The boost curve is more steeper on the MFD.:)
1 - 15 of 15 Posts
