Hi all,
GTR-32 problem !
In the picture below, there is a pipe connected to the drivers side of the front diff.
Location is just under the oil filter, onto a brass nipple at the top of the diff case located just over the off-side front drive shaft (where the CV spline slots into the diff)
Oil filter has been removed in the photos so as to see where the pipe joins the diff case.
Can anyone tell me where the other end of this pipe is to be connected ?
It has never been connected although it has a spring clip on the end of it ??
Any help would be good.
Cheers,
Stuart.
diff pipe
this pipe is just a breather it normally has a small metal tube like a horse shoe shape in the other end and a bracket to bolt it to the underside of the plenum .it just breathes to atmosfere
