I'm forging a block atm and I want to keep the comp ratio as close to stock as poss so it's still responsive off boost
I'm looking at CP Pistons and they vary from 9.0:1 to 8.5:1 to even lower I've seen some CP Pistons 87mm with a 9.0:1 cr I've been advised to run a 1.5mm head gasket is this a good combo
Searching using tapatalk is shite and don't bring anything up
