I used the plastigauge to measure oil clearance for my con rods last night "im using eagles now"
readings were like the following :
in mm
no.1 0.038
no.2 0.038
no.3 0.038
no.4 0.025
no.5 0.025
no.6 0.025
all using my old bearings which were :
no.1 std1
no.2 std0
the rest are all std 1
so I guess the best thing to do is go with :
std 2 "1.503-1.506 oil clr : 0.021-0.40" for cylinders 1,2,3 "to tighten the gap"
std 0 "1.500-1.503 oil clr : 0.020-0.039" for cylinders 4,5,6 "to loosen "
Just want to double check ..a little feedback please
For the mains I'm using 4x std 3 and 3x std 4 "According to the table"
note: My crank has never been grounded
thanx
