Platinum Detailing Package
"The Mirror package"
High protection with a deep mirror shine finish. Suitable for cars with light defects, e.g. micro marring, light paint swirls and holograms.
After following the same processes from our Gold detail package, your paintwork will be checked for any micro marring, light scratches, bird/water marks, "Swirls" or "Holograms". Once your paintwork has been assessed a single stage machine polish is used to remove as many defects as possible before applying Dodojuice high Carnauba content wax or Dodo Juice Supernatural high Carnauba content hybrid wax (sealant and wax combined) to protect your paintwork from any future defects.
[We may require your vehicle for up to a maximum of 48 hours, but only in extreme circumstances.]
Cost: £180
£40 Extra for plus size vehicles.
Examples:
Vans: Ford Transit, VW Transporter, Mercedes Sprinter ect
Pickups: Nissan Navara, Toyota Hilux, Dodge Ram ect
4x4: Range Rover, Discovery, Mitsubishi Shogun ect
Vehicle rinsed using low pressure filtered water
Lower third sprayed with a non caustic citrus cleaner, and rinsed
Wheels, arches and door shuts cleaned by hand with a non caustic citrus degreaser
Wheels cleaned with a pH neutral wheel cleaner
Vehicle sprayed with a pH neutral snow foam, left to dwell and rinsed
Hand washed using a sheep wool mitt, with a pH neutral shampoo using 2 bucket method
Tar removed from vehicle
Hand dried using high quality, specialist, microfibre drying towels
Clay bar/clay sponge paintwork and glass to remove any contamination
Paintwork is inspected using a high Lumen light. Vehicle is then masked to protect trim, plastics and windscreen and then corrected using a single stage machine polish, removing as many swirl marks, micro marring, light scratches, holograms, and bird/water marks as possible.
Pre-wax cleanser applied to ensure bonding of protection layer
Vehicle wiped down with IPA (Isopropyl alcohol) solution to remove any contaminants or oils from the polishing stage
Dodojuice high Carnauba content wax or Dodojuice Supernatural hybrid wax applied to paintwork, and door shuts
Chrome/stainless steel polished including exhaust tips
Interior glass cleaned
Exterior windows and mirrors cleaned
Layer of detailing spray applied
Tyres cleaned and tyre dressing applied (satin finish)
Final inspection to make sure your car meets our high standards
Cost: £180
Examples:
