Hi there i need some help with the install of my HKS electronic valve controller or boost controller.in the instructions it has three lines if you can help me with finding the proper hook ups.
First to make sure the stock turbo is a Internal wastegate single port actuator?
these are the lines i need help with.
Where is a uniterrupted intake manifold presaure source after the throttle body,such as a compressor bypass signal?
where is a source of pressurised air such as a turbo compressor housing discharge side or compressor outlet pipe befor intercooler?
Where is a port on the wastegate actuator?
if you can help me that would be amazing or if anyone has a picture to show me.
also i have a GTS-4 so i dont have a boost gauge.
thanks very much.
