1 - 20 of 64 Posts
It has occurred to me that anybody visiting this forum only gets a bad impression of a GT-R with all the problems posted So I would like to correct that by having people post the mileage that the car has covered with them and had no problems. Like myself :) so my car is a 59 plat I covered 5000 miles in 4 months since owning the car and I have had no problems at all it has a stage one Litchfield turn and latest gearbox software and I have only ever launched it twice.
Regards
Tim
2010 car 20000 miles been stage 4 for 3000 of them , no problems at all in the 18 months I have had it
2009 car , 28k miles, never missed a beat. Literally nothing.
It's not as well built as my ISF was but it is über reliable
Regards
Tim
I forgot to say what milage my car has done 21534
Late 2010 car, 35k miles, no problems whatsoever, except for a misted headlight which was replaced under warranty. The bellhousing is rattling a bit now, but not too bad yet...
Did 20000 miles in 2 years in mine before I sold it. Was running stage 4 with DPs for a year.
Never had any issues. Did a sprint and a couple of trackdays aswell
2010 late one 20k with no probs at all.
Bobby
Ooo Matron !
But that's true for any car forum. Read the Noble forum on PH and you'll leave with the impression that every single car ever made is failing to bits -you'd never buy one ! It's the same with the Aston Martin forum on PH as well (but maybe not quite as bad).
It's like visiting the doctor - your don't make an appointment with you GP to tell them you are feeling fine !
Other than.
Steering column ecu failure
Gearbox solenoid issue
Gearbox shift fork snapping
Rear struts leaking
Display unit failure
Bell housing rattle
Electrical fault
Mines been flawless in my 2 and half years
36,000 miles in my first 2009 GT-R with no issues apart from one bellhousing bearing that was replaced under warranty.
43,000 miles in my second MY11 GT-R which has been modified by Litchfield's to stage 4.5 with upgraded brakes and suspension. Three headlights replaced under warranty and two bellhousing bearings. One gear box sensor went which was a one off and other than a high investment in Litchfield's which was my choice, no other issues.
I would add that I probably have the car serviced more than it should and more fluid changes than most other cars purely because I use the car, as it was designed, on track a lot.
In my opinion, no other car would have taken the abuse I give it other than a GT-R, and at 36,000 miles I decided to change the engine and have the gearbox rebuilt as a precaution. Quite simply, it wasn't necessary as when inspected, there was a perfect engine with one loose timing chain tensioner in the engine and the gearbox was spot on.
Some on the forum know how much I use the car on track and this was the perfect test to see how the R35 GT-R had faired under harsh conditions, and the answer was simple - it coped better than anyone expected.
If you track a car a lot then consumable costs will rise such as brake discs and pads, tyres, and all fluids that need changing. Windscreens are a consumable with me and as long as the OEM Nissan ones are fitted there is no problem.
To summarise, if you use it a lot on track then expect to spend a lot on consumables, and if you use it as a daily drive then you will have one of the most reliable road cars with incredible performance on the roads today - just maintain it as per the manufacturers schedule.
Discussion Starter · #14 ·
I know exactly what you're saying and I agree with you 100% about forums but it's just nice and a bit reassuring to have a thread where you can actually see where cars haven't developed any problems
2010 - No issues been brilliant. Did Rico Rally in it and with audis r8's and Bentleys having problems, shows the car is built for purpose!
2009 model, bought it a year ago stage 1, put about 15k miles on it since then including 2 track days and a lot of strain on 6 days of cat driver courses at milbrook and bruntingthorpe, the car has been reliable so far, ive started getting a few peoblems lately but thats since ive modified it.
4 years and 21k miles mostly at stage 4 and 5.
Bellhousing replaced and that's it
Out of all these cars only 1, yes only 1 has done over 30,000
Up until 29500 miles my car was also flawless and amazing.
Then gearbox issues twice!
and the normal bellhousing replacement.
Discussion Starter · #19 ·
That's a good point you wouldn't class 30,000 miles is a lot would you
My RS4 b5 had done 179500 when I sold it
1 - 20 of 64 Posts
