Second question for the day is....
I want to permanently remove my plug cover and notice that the ignition amp sits in a cradle in the cover. Question is, for those who have this cover removed, where have you relocated your amp? Is it lying around loose or have you attached it to something?
TT
Ive removed mine and cut the back end of the cover off ,the piece with the amp on and bolted it back on .
ill post a pic up later
Bolted mine straight onto the cover, if you put it on the left side the earth wire still reaches to its original fitting.
I did the same as leggus whilst mine was away for paint, worked fine. I also put a tywrap around the breather hose to one of the unused hols in the amp.
Thanks guys. Just been out and sorted it all out. Many thanks.
TT
