1 - 8 of 8 Posts
Does anyone know if there is any kind of dis-advantage to removing the black paint from the inlet manifold/pipes on the RB26DETT ? I was just reading some other threads and it got me thinking, There must be a reason they are painted, and the only reason I can think to paint them black in the first place is Heat dissipation. So surely removing the black would have some effect ? or am I talking out the wrong hole again ;)
Just FYI the R34 had no paint!!!
Cheers, So its just the 33 and 32 then, The GTSt has no paint on the manifold either...
Yeh R32 and R33 are painted black. The R34 is just bare metal obviously with the textured casting finish
they look nice polished.. its not that hard just takes a bit of elbow grease!!
but easyer to get some else to do it:wavey:
I've polished stuff like that by hand in the past. I started with 60 grit emery paper to get it flat (so that the casting finish didn't show). I then went on to P120 wet and dry (used wet), followed by P240, P400, P800 and finally P1200. I then buffed up with Solvol Autosol. At each stage, rub until the marks from the previous stage are no longer visible.
1 - 8 of 8 Posts
