Could you not just swap them left to right in that case?Front caliper piston stagger is opposite to R32 as most 911's have trailing rather than leading caliper.
The best match I could find piston wise was one of the Brembo 6 pot designs. THere are two versions one with bigger pistons (total area) and one with smaller pistons. I can't remember exactly which way round it was but one was a reasonable match (probably the smaller piston item).Thinking of going down this route but have no idea of fitting etc. 4 pot front and back.
Anyone had any experience? Tips? Will it work? What to look out for?
£ for £ I'd say teh Akebonos would be the best bet. Kits form the US are pretty cheap and being OEM brakes you should be able to get parts easily.Always hate researching brakes. Leads me to all the way to thinking about retrofitting some carbon astons. Have also read about 370z akebonos, d2/ksport, alcon. wilwood, ap, brembo gt...........
Why can't it be easy?
2.5k wow wtf. Why not alcon or the other big names? Could you get endless for that much?Set a budget and take a pick. I was the same couldn't decide which way to go. In the end I saw the best brakes I could buy for 2.5 k were the R35 brembos.
Are you running the stock MC?I thought about it long and hard. I'm not going to be using the car for track (very rarely once in a year or so I guess) so buying a massive kit would just be wasting the use of it. Didn't want to be faffing about with making brackets etc. Went instead for the old school 4 pot grex alcon kit for the front.
Is it better to start looking for a matching rear set? Or should I go for 33/34 set up on the back with good pads? Will there be an issue of bias?
Yeah stock at the moment but will be changing that over to a bm57, or if you know where I can get a stagea one from I'll run that as supposedly that is the best? Apart from AS.Are you running the stock MC?
Easiest rear upgrade is the Brembo. Given the weight distribution of the car I cannot see much need for more on the rear calipers (i.e. 2 pot opposed should be fine) for a road car.
I'll tell you how I get on with mine when Bob fires them over.
Late model R34 uses a larger rear disc. I forget exactly but it's something like 323mm vs 300mm. The caliper has longer mounts to suit. I beelive that the calipers are gold rather than red.Yeah stock at the moment but will be changing that over to a bm57, or if you know where I can get a stagea one from I'll run that as supposedly that is the best? Apart from AS.
I'm thinking of going for a 34 n1 rear set up, from what I know it's different to standard as it pushes out the disc and calliper? Am I correct in thinking that to install it on the 32 I'd have to drill bigger holes?
