I want to replace my two standard lambdas with Bosch widebands (LSU 4.2) - will they be compatible with my Power FC? Or will I need some kind of converter? The stock R32 "titanium" lambdas return voltages between 1.1V and 4.8V during running, and one sensor gives weaker voltage readings than the other (ideally, should they give the same readings?).
Also, my Apexi turbo timer has a O2 lambda lead (to measure and give rough A/F readings), can that take a Bosch signal direct?
