1 - 9 of 9 Posts
I have a power fc l-jetro and depsite the fact that I try to initialize the setting to default, it seems to retain all the changes.
Does anyone know the default ignition map, injector map and airflow setting?
Is the unit locked? If so it will show 0 on all the ignition map.
The other reason they can do this is if there is a wiring fault on on of the power feeds.
Richard
It doesn't seem to be locked as I can adjust the ignition map but the numbers don't seem to have changed from the numbers prior to the reset and I know they can be the baseline numbers as I made a few changes before I did the reset.
did you cycle the ignition i.e turn it off then back on then press read all the values again on the unit
So what you are saying is that after in re-initialize using the commander, I must cycle the ignition to complete the reintialization? Not sure whether I did that. I'll give it a try thanks.
Discussion Starter · #8 ·
I finally got it to work. Was over on Skylines Australia and was told to leave the ignition off for a few seconds when I cycle it and that worked. Thanks for your help.
1 - 9 of 9 Posts
