hello gtr people ,as the title says ,im using a power fc with 1000cc sard injectors
with no problems,
im running out of injector so decided to buy what i was told bye the manufacturer was a drop in set of 2000cc injectors i dentical impedance to the sard set i run which are low impedance,
ive re configured the power fc percentage and lag time ,
the injectors will not trigger,
ive bench tested all the injectors with battery voltage and the trigger ,
im not sure if the power fc injector drivers can tigger these ,
ive looked into a ecu upgrade, to a link ecu but ive noticed the gtr link ecu runs the stock balest resistors as well so would require low impedance injectors ,
i no power fc on rx7 subaru and mr2 run way bigger than 1000cc injectors,
am i over looking something obviouse i realy hope so ,
any help on larger than 1000cc injectors wqith power fc would be much apretiated thanks guys
Discussion Starter #2
any body
any body ever run larger than 1000cc injectors with power fc d jetro
if so what brand ect
any help would be apretiated thank you
I ran 1600cc injectors on my Power FC a few years ago.
Ran perfectly, can't remember the brand right now, but will have a look to see if I have any emails and let you know.
I will have some low mileage ID2000 injectors from my R35 available shortly if that would be of interest.
