Removed all my HICAS gubbins years ago but have just gotten around to removing the HICAS ECU.
Looking at the wiring diagram the HICAS ECU sends a signal to the PAS solenoid located in the fluid feed pipe. Having read many a comment on here about folks experiencing heavy steering after HICAS ECU removal, clearly there is a connection.
First of all, I need to understand how the solenoid operates...i.e is it a simple on/off operation or is it linear? I'm guessing that the solenoid either introduces or removes a flow restriction in the fluid feed line.
I have 2 options......
1. Take the original wire (from HICAS ECU to solenoid) and connect it to an output on my main ECU and provide it with (and this is where understanding the solenoid operation is required) either a fixed voltage to operate (on/off) or a programmed variable voltage (linear) to basically replicate the original output of the HICAS ECU.
2. Remove the solenoid completely and replace with appropriate grub screw to seal. Being a track only car I'm thinking this might be the best option but unsure of just how heavy 'heavy' actually is!!!
So, can anyone with knowledge of the solenoid operation explain to me if it is indeed an fixed (on/off) or variable (linear) voltage that is supplied to it?
TT
TT
