1 - 13 of 13 Posts
Cool 200kpa do you inflate then check via screen to double check of sorts as not sure how accurate tesco pressure gauge is lol
Tyres are normally filled with Nitrogen but i think some may say normal air isn't an issue. Not sure in KPA as mines just PSI on my screen. I double check mine on the screen after i have done the pressures just to be sure.
Hey mate if you go on to the screen which displays the tyre pressures it will have a button on the bottom right saying " select units " then you can choose from KPA and PSI.
1 - 13 of 13 Posts
