1 - 9 of 9 Posts
Hi All,
I seem to have a problem with the car. No power seems to be going to the coil pack loom (RB26). Its not the immobiliser.
Are there any fuses which might cause this problem ?
One of the relays in the foot well by the ecu powers the amp pack. I would check there first.
If you have a multimeter you can check for power on the 2 pin plug on the coil pack loom. (think its the white wire)
Richard
Power is getting to the Relay, but not coming out of the relay.
Swapped over the relays to a known working one, but still no joy. Am I correct in thinking this relay is controlled by the ECU ?
im also having problems with this.i have no power up to three pin plug for the coils.relays are clicking and im having 12 volt to relays when ignition at off position.anyone got some good diagrams of this please.everything else works.i have power to cas,injectors etc.can anyone help.the engine is in a s13.i had the loom done professionally.
1 - 9 of 9 Posts
