Hi All,
Can anyone tell me what could be the problem with this greddy Profec unit.
There's a red light flashing on the boost gauge and the read out on the unit shows a negative boost?.
The car is running perfectly checked all the lines/wires to and from components, all O.K. Can anyone thro any light on this, has anyone had a similar problem?
Thanks.
im just guessing
have you reset the peak hold?
normally the red means its hitting the "limit" youve set on the profec
i assume this is a second hand unit youve re plugged into your car?
