1 - 6 of 6 Posts
Anyone who has read my recent thread will see that the concensus of opinion is that the turbo shown is standard and not uprated. I has a sneaking suspicion that this may be the case and therefore had already ordered from member on here for a GTSt a "T3/T4 P trim, Comp A/R is 0.50 and the Turbine A/R is 0.64" turbo.
These were also for sale in another forum where the seller was asked:
"do these bolt straight on, no fuss? or will they require new exhaust, oil/water feeds?" and replied:
"IT bolts right up ....."
The turbo arrived today and I have copied some pictures below. What I know about cars and mechanical engineering can be written on the back of a postage stamp, but the fittings to my eye look nothng like the standard turbo that I have already got.
Is anymore able to venture an opinion on whether the turbo will "bolt right up"? Or have I bought yet another pup, I'd like some view before I approach the seller.
TIA
mf. (collector of Turbo's)
[/URL][/IMG]
[/URL][/IMG]
Well the compressor outlet will be pointing at the block for a start.Then the elbow flange looks wrong.No waste gate in the turbine housing ETC,etc
That looks like a GT30 turbine housing - the wastegate poppet lives in the backing plate that bolts to the turbine housing (nasty design as well!). I assume you don`t have the backplate?
Paul - hows things?
That turbo is a T3/T4 hybrid.
It has a T4 compressor with a T3 turbin and turbin housing. This turbo should fit the exhaust manifold but nothing else should be bolton I guess. And you would need a T3 wastegate actuator with fitting plate to use it with internal wastegate.
// Stefan
// Stefan
Correct,
I would be asking for a refund if you feel you were miss-lead.
Discussion Starter #6
ahapartridge said:
Correct,
I have already tried that without success seehttp://www.gtr.co.uk/forum/upload/showthread.php?t=58633 and am deafened by the silence of the response from the seller.
Anyway I now need to concentrate on making the best of a bad job and getting the necessary parts to fix what I have got to the car.
I think I'll let my tuner have the car and turbo and just let him get on with it.
Thanks for all the advice.
1 - 6 of 6 Posts
