1 - 12 of 12 Posts
R35 Section manager
Hi Chaps,
On starting my GTR 33 1995,the Hicas light is staying on. If I switch the car off and re start it it will go out.
It has started to come back on whilst driving now tho.
I have checked the power steering and brake fluid-Both fine.
I have done a search,but cant find the same problems.
Please help.:mad: :confused:
Possibly the steering postion sensor on th steering column. Common fault on R32's, so I assume maybe same on R33's.
Miguel
take it to a nissan dealer and get the consult plugged in to see what the fault is. The 32 and 33 hicas systems are different in there components and operation.
Maybe this is a sign!
Get a HICAS replacement bar and shave 50kg off the wieght (or so i've heard!)
Just a thought
Sev
Heard wrong. The Aussies and a few others on other sites and threads weighed the difference and it was only about 5kg difference with a lightweight bar added in :mad: So no point doing to save weight unless you remove the whole system and even then it's not a great amount of weight saved (about 8kg).
Some 240sx owners also removed the "whole" HICAS system and weighed them with the following results...
HICAS solenoid - 6.4lbs (~3kg)
rear HICAS rack - 10.8lbs (~5kg)
rear HICAS distribution block - 5.2lbs (~2kg)
R35 Section manager
Discussion Starter · #11 ·
I think the problem is due to the power steering fluid running low.Possible leak??
Think I may need to give Abbey a call,unless someone can think of an idea???
R35 Section manager
Discussion Starter · #12 ·
Took it to Abbey today,it turned out to be a steering sensor £187 inc labour.
Hopefully thats the end of the problem now.
1 - 12 of 12 Posts
