Hi Guys,
A friend of mine is trying to fit a Profec B into a 200sx.
Im attaching a picture to try and help him. Which pipe goes where?
On the control boc there is an outlet which says 'pressure in' and on the bigger box one outlet pipe says 'in' and the other says 'out'
Cheers Guys
Tony
on the control box(pressure in) you want manifold feed (after throttle body, same pickup as dump valve vacum or boost gauge), the IN on the solenoid is the pressure source (usually nipple on turbo inlet housing) and OUT will go to the wastegate actuator.
I the car has a standard solenoid in place you can trace back the pressure source and actuator line and remove them from the solenoid and just link to the greddy solenoid. If not try as above.
