1 - 20 of 72 Posts
had a gtst for about 11 years and was getting it ready to be back on the road when a gtr shell came up so thought i woud start a fresh project thread.
this will have gtst running gear and engine.
what im starting with.
done some already but its dark so ill update when i get pics
Having done this exact project I can tell you about some of the issues you are going to face, things like gearbox cross member, front hubs and wiring differences.
Have a look for my project thread there are loads of pictures
Good luck and I can't wait to see the end result!
The gtr chassis has a cut out for the 4wd transfer box that the gtst doesn't so the gts cross member doesn't fit and the gtr cross member doesn't fit the gts gear box. You will need a custome one fabricating.
Also the gtr steering rack wiring doesn't have the same connections as the gts wiring loom so you either need to mod that or change the rack AND steering column. The front chassis rails have cut outs for the front driveshafts so you have to use the gtr sub frame.
The front drive shaft also holds in the wheel bearing so I just cut them down the cup and had them balanced.
Discussion Starter · #13 ·
will be this year wayne, my gtst was almost done just needed gtr rears welding on and this saves me doing that.
well i started removing the 3 ton of dynamat and managed to cut my hand, will finish and pic the progress soon
Discussion Starter · #16 ·
it weighs a ton, my gtst had 6kg of it on each door, not weighed this yet but it will be around there. i will be running this down the drag strip and around tracks so any weight off will help
1 - 20 of 72 Posts
