1 - 9 of 9 Posts
Project: 'VSPEC'
Date Started: 01/07/2006
Car Specification:
Four way adjustable rear spoiler
Uprated two-arm construction to the upper front multilink suspension
Rear suspension travel has been increased and stiffer anchor points all round
Yaw rate feedback added to the Super HICAS system
6 pot Brembo brakes as standard and revised ABS control parameters
ATTESA E-TS PRO can redirect up to 50% of the torque to the front wheels within 1/1000th of a second
Active LSD system splits the torque between the rear wheels
Hard, 10mm lower Nismo suspension setup.
Performance Stats (de-restricted):
power output 310bhp @ 8000 rpm
torque ft/lbs 303 @ 4400 rpm
0-40 mph - 2.7s
0-60 mph - 5.3s
0-80 mph - 9.1s
0-100 mph - 12.9s
0-1320 ft (1/4 mile) - 13.4s @ 112 mph
top speed 180 mph
Modifications:
18'' R34 GTR gold nismo alloy wheels
Blitz Fatt turbo timer
Nismo boost guage
Pictures:
last updated: 04/09/2006
Hey there,
I am just wondering how you added / have adjusted these items.
-Yaw rate feedback added to the Super HICAS system
-ATTESA E-TS PRO can redirect up to 50% of the torque to the front wheels within 1/1000th of a second
-Active LSD system splits the torque between the rear wheels
Did you have to purchase aftermarket controllers? Im not sure but i was of the impression that the attessa e-ts pro came standard on the vspec models.
Is the active lsd a standard item too or something aftermarket?
Also how did you add the yaw feedback control to the super hicas? did you either upgrade to a later model controller and add the required sensors or modify (a big job) the system yourself?
If you could provide some links to these bits i would appreciate it.
lovely car chris i wanted to buy this from jurgen at jm-imports but could not afford it and still cant.
nice car you got any plans ??
1 - 9 of 9 Posts
