1 - 9 of 9 Posts
Can propane injection such as used on diesel engines in the USA be used as a cheap way to add power to a modern turbocharged gasoline engine?
I read that the octane rating of propane is 110. Is that correct? Would that be enough to enhance performance significantly?
Are there any beneficial (better burn, cleaner engine) or detrimental side effects to using propane injection?
1 - 9 of 9 Posts
