Administrator
RB CAM AND CRANK COMPLETE TRIGGER KIT WITH CAS BRACKET
Platinum Racing Products
€795,00
RB CAM and Crank Complete Trigger Kit with CAS Bracket
  • RB CAM and Crank Complete Trigger Kit with CAS Bracket
If you need to inquire about this part please email us at [email protected] or click on the icon.
This RB Trigger kit has evolved, through research and development to offer precision ignition timing, for high powered and high RPM applications.
We have re developed the bottom timing gear with trigger disc to be one piece, this disallows a screwed on trigger disc to ever come loose.
This custom made gear will work with all and any balancer.
The cherry hall effect magnetic pickup timing gear sensor is now the industry benchmark, the cam sensor bracket is light and simple and incorporates the use of a smaller more discreet cherry sensor.
Design Features:
  • Billet alloy bracket.
  • Engineered timing gear with incorporated trigger disc.
  • Gear works with any known balancer.
  • Bolt kit included.
  • Lifetime warranty on all Platinum Racing Products hardware.
