1 - 8 of 8 Posts
No modification needed. Your gearbox should already have the mounting holes both sides at worst you may need to tap the thread in if they are blank.
He is after a replacement for his push type slave cylinder, so no modification will be need.
Correct, R33 are all pull from the factory unless he has had Push conversion done in which case no mods would be needed.
1 - 8 of 8 Posts
